Your basket is empty
Be Quiet BK012 Shadow Rock TopFlow SR1 CPU Cooler
Quicklinx: B1CPWS00 Mfr#: BK012
The decoupled 135 mm Shadow Wing's PWM fan ensures a perfect mix of cooling power and noise production. The waveshaped contour on the cooling fins minimizes noise and optimizes the air flow.
Four 8 mm heatpipes transport the heat along the shortest path to the optimal point within the cooling fins. The TopFlow cooler-layout enables ideal cooling not only for the CPU but also for surrounding components.
be quiet! Shadow Rock TOPFLOW SR1 - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket
Heatsink Material
Nickel plated aluminum
Fan Diameter
135 mm
Fan Height
25 mm
Rotation Speed
900-1500 rpm
Air Flow
66.8 cfm
Power Connector
4-pin fan connector
Pulse-width modulation (PWM) support, 4 copper heatpipes
13.7 cm x 17 cm x 12.5 cm
0.65 kg
Anti-vibration
3 years warranty
Processor cooler
Package Content
Thermal paste
13.7 cm
17 cm
12.5 cm
0.65 kg
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
135 mm
Fan Height
25 mm
Rotation Speed
900-1500 rpm
Air Flow
66.8 cfm
Air Pressure
2.1 mm
Noise & Performance Details
9.6 dBA at 900 rpm , 15.9 dBA at 1200 rpm , 24.4 dBA at 1500 rpm
Power Connector
4-pin fan connector
Rated Current
0.22 A
Mounting Kit
Included
Anti-vibration
RoHS, WEEE
Limited warranty - 3 years
