Be Quiet 850W PSU - BN253 Dark Power Pro 11
Quicklinx: BGW7WS00 Mfr#: BN253
It is a fact of the modern world that high technology requires constant refinement and unending improvement - and that is even truer for those who would be leaders. Dark Power Pro power supplies are renowned as quiet and efficient high-performance PSUs. The Dark Power Pro 11 850W model takes that a step further with a power conversion topology that delivers high performance, add to that an unparalleled array of enhancements that augment this unit's compatibility, convenience of use, reliability, and safety, and the result is a technologically-advanced power supply.
be quiet! Dark Power PRO 11 850W - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
2.38 kg
Input Voltage
AC 100-240 V
Power Capacity
850 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 1 x power 8 pin +12V with detachable 4 pin section , 7 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 6 x 8 pin PCI Express power with detachable 2 pin section , 1 x 6 pin PCI Express power , 2 x 4 PIN mini-power connector
Cooling System
135 mm fan
Cable ties, thumbscrews
15 cm x 19.3 cm x 8.6 cm
Environmental Standards
ENERGY STAR
5-year warranty
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
850 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V1 - 30 A , +12V2 - 30 A , +12V3 - 35 A , +12V4 - 35 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
94.38% at 50% Load, 92.4% at 100% Load, 92.4% at 20% Load
Modular Cable Management
80 PLUS Platinum
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
135 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, 4 x 12V rail, temperature controlled fan, CrossFireX ready, Intel 4th-gen CPU (Haswell) compatible, fluid dynamic bearing cooling fan, semi-modular
TUV, CB, FCC, RoHS, WEEE, cTUVus, ERP, RCM, CU-TR
ENERGY STAR
Limited warranty - 5 years
15 cm
19.3 cm
8.6 cm
2.38 kg
Shipping Width
34.8 cm
Shipping Depth
27.2 cm
Shipping Height
11.8 cm
Shipping Weight
4.59 kg
