Be Quiet 700W PSU - BN269 Pure Power 9 CM Modular Rifle Bearing Fan
Quicklinx: C1JWWS00 Mfr#: BN269
The Pure Power 9 PSU series stands for peerless dependability and amazing features. Whether you are assembling a very quiet system, upgrading an existing PC, or building a multimedia or multi-GPU gaming system, your build will benefit from this PSU series that simply has a perfect combination of features, performance and quality.
be quiet! Pure Power 9 CM - power supply - 700 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Silver
2.16 kg
English, German, French, Polish, Russian, Spanish
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
+3.3V - 25 A , +5V - 20 A , +12V1 - 36 A , +12V2 - 30 A , -12V - 0.3 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
120 mm fan
Cable ties
15 cm x 16 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3-year warranty
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
Efficiency
90.9% at 20% Load, 91.9% at 50% Load, 89.2% at 100% Load
Power Factor (PF)
0.99
80 PLUS Silver
Cable ties
Power cable - integrated - 1.5 m
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, dual 12V rails, short-circuit protection, CrossFireX ready, active CLAMP circuitry, semi-modular
TUV, BSMI, CB, FCC, WEEE, cTUVus, RCM, ErP 2014, CU
Sustainability Information
ENERGY STAR
Limited warranty - 3 years
15 cm
16 cm
8.6 cm
2.16 kg
Shipping Width
24 cm
Shipping Depth
21 cm
Shipping Height
9.6 cm
Shipping Weight
2.38 kg
