The Pure Power L8 600 W proves true affordability, means peerless dependability and best-in-class features - not cutting corners and settling for less. Pure Power L8 600 W features rock-solid voltages, strong reliability, high efficiency and exceptional quiet - simply the best combination of features, performance and quality in the class - at a very popular price.
- be quiet! Pure Power L8-600W - power supply - 600 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Bronze
- 1.93 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- Included Accessories
- Cable ties
- 15 cm x 15 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 3 years warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- +3.3V - 25 A , +5V - 18 A , +12V1 - 30 A , +12V2 - 30 A , -12V - 0.3 A , +5VSB - 3 A
- Efficiency
- 84%
- 80 PLUS Bronze
- Cable ties
- Cables Included
- Power cable - external - 1.5 m
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, CrossFireX ready
- TUV, SEMKO, CB, FCC, RoHS, WEEE, cTUVus, ErP Ready
- ENERGY STAR
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Sound Emission
- 27.4 dBA
- 15 cm
- 15 cm
- 8.6 cm
- 1.93 kg
- Shipping Width
- 23 cm
- Shipping Depth
- 28 cm
- Shipping Height
- 10.5 cm
- Shipping Weight
- 2.4 kg
