Product
Be Quiet 550W PSU - BN250 Dark Power Pro 11 Modular Fluid Dynamic Fan
Quicklinx: C1JPWS00 Mfr#: BN250
Power Rating: 550Watt
Hurry, only 2 left in stock!
£105.28 ex VAT
£126.33 inc VAT
It is a fact of the modern world that high technology requires constant refinement and unending improvement - and that is even truer for those who would be leaders. Dark Power Pro power supplies are renowned as the world's quietest and most efficient high-performance PSUs. The Dark Power Pro 11 550W model takes that a step further with a power conversion topology that delivers 80PLUS Platinum performance, add to that an unparalleled array of enhancements that augment this unit's compatibility, convenience of use, reliability, and safety, and the result is the most technologically-advanced power supply be quiet! has ever built.
be quiet! Dark Power PRO 11 550W - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
2.02 kg
Input Voltage
AC 100-240 V
Power Capacity
550 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 1 x power 8 pin +12V with detachable 4 pin section , 5 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 4 x 8 pin PCI Express power with detachable 2 pin section , 1 x 6 pin PCI Express power , 1 x 4 PIN mini-power connector
Cooling System
135 mm fan
Cable ties, thumbscrews
15 cm x 18 cm x 8.6 cm
Environmental Standards
ENERGY STAR
5 years warranty
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
550 Watt
Output Current
+3.3V - 25 A , +5V - 22 A , +12V1 - 20 A , +12V2 - 20 A , +12V3 - 25 A , +12V4 - 25 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
94% at 50% Load, 91.6% at 20% Load, 92% at 100% Load
Power Factor (PF)
0.99
Modular Cable Management
80 PLUS Platinum
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
135 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, short-circuit protection, 4 x 12V rail, temperature controlled fan, CrossFireX ready, fluid dynamic bearing cooling fan, semi-modular
TUV, CB, FCC, RoHS, WEEE, cTUVus, ERP, RCM
ENERGY STAR
Limited warranty - 5 years
15 cm
18 cm
8.6 cm
2.02 kg
Shipping Width
34.8 cm
Shipping Depth
27.2 cm
Shipping Height
11.8 cm
Shipping Weight
3.37 kg
Brand: Be Quiet
Price Range Ex VAT: 100 - 150
