Your basket is empty
Be Quiet 500W Pure Power L8 Rifle Bearing Fan APFC 80+ Bronze PSU
Quicklinx: 9BQ6WS00 Mfr#: BN223
The Pure Power L8 500 W proves true affordability, means peerless dependability and best-in-class features - not cutting corners and settling for less. Pure Power L8 500 W features rock-solid voltages, strong reliability, high efficiency and exceptional quiet - simply the best combination of features, performance and quality in the class - at a very popular price. Now that is value!
be quiet! Pure Power L8-500W - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
1.93 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties
15 cm x 15 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3 years warranty
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+3.3V - 24 A , +5V - 15 A , +12V1 - 28 A , +12V2 - 20 A , -12V - 0.3 A , +5VSB - 3 A
Efficiency
84%
80 PLUS Bronze
Cable ties
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection
TUV, SEMKO, CB, FCC, RoHS, WEEE, cTUVus, ErP Ready
ENERGY STAR
Limited warranty - 3 years
Sound Emission
25.1 dBA
15 cm
15 cm
8.6 cm
1.93 kg
Shipping Width
23 cm
Shipping Depth
28 cm
Shipping Height
10.5 cm
Shipping Weight
2.19 kg
