Especially designed by be quiet! with the price-conscious PC builders in mind - the be quiet! System Power 8 400W, featuring true be quiet! reliability with two 12V-rails and rock-solid voltages. The series is certified 80PLUS efficient and able to support multiple GPUs with two PCIe connectors.
System Power 8's combination of power, quietness for its class and efficiency is far beyond ordinary, letting you build cost-effective and reliable systems - a key differentiator in these days of identical commodities.
- be quiet! System Power 8 400W - power supply - 400 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4
- 80 PLUS Certification
- 80 PLUS
- 1.75 kg
- Input Voltage
- AC 200-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 400 Watt
- Output Current
- +3.3V - 24 A , +5V - 15 A , +12V1 - 22 A , +12V2 - 18 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 5 x 15 pin Serial ATA power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- ATX12V 2.4
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 200-240 V
- Frequency Required
- 50 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 400 Watt
- Output Current
- Efficiency
- 86%
- Power Factor (PF)
- 0.98
- 80 PLUS
- Cables Included
- Power cable 1.5 m
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection
- TUV, CB, RoHS, WEEE, RCM, ErP 2014, CU
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years
- 40 °C
- Sound Emission
- 25.1 dBA
- 15 cm
- 14 cm
- 8.6 cm
- 1.75 kg
- Shipping Width
- 19.5 cm
- Shipping Depth
- 9.7 cm
- Shipping Height
- 26.8 cm
- Shipping Weight
- 2.1 kg
