Be Quiet 300W PSU - BN228 TFX Power 2 Small Form Factor 80+
Quicklinx: BGVZWS00 Mfr#: BN229
TFX Power 2 300W Gold, the high-efficiency compact PSU, gives you much more for your mini or media PC. The imperative during its design was to achieve the maximum possible energy efficiency, power to support a discrete PCIe graphics card and silence without compromising quality or features.
For compact PC systems that perform well beyond the ordinary, with the best possible combination of quietness, features, reliability and super-high efficiency, choose TFX Power 2 300W Gold.
be quiet! TFX Power 2 300W - power supply - 300 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
TFX12V 2.4
80 PLUS Certification
80 PLUS Gold
1.08 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
300 Watt
Output Current
+3.3V - 18 A , +5V - 18 A , +12V1 - 13 A , +12V2 - 13 A , -12V - 0.3 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 6 pin PCI Express power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 4 x 15 pin Serial ATA power
Cooling System
80 mm fan
Cable ties
8.5 cm x 17.5 cm x 6.5 cm
TFX12V 2.4
PSU Form Factor
TFX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
300 Watt
Output Current
Efficiency
92%
80 PLUS Gold
Cable ties
Power cable - external - 1.5 m
MTBF
100,000 hours
Cooling System
80 mm fan
Over current protection, over voltage protection, overload protection, undervoltage protection, dual 12V rails, short-circuit protection, non-modular
TUV, CB, RoHS, WEEE, ERP
Sound Emission
26.5 dBA
8.5 cm
17.5 cm
6.5 cm
1.08 kg
Shipping Width
15.9 cm
Shipping Depth
19.5 cm
Shipping Height
8 cm
Shipping Weight
1.4 kg
