Product
Brand
Ballistix Tactical Tracer 8GB DDR3-1600 1.5V UDIMM Memory
Quicklinx: 9JBLWS00 Mfr#: BLT8G3D1608DT2TXOBCEU
Crucial Ballistix Smart Tracer memory starts with everything you love about the Ballistix Tracer: activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom. And then Crucial has added more!
The Ballistix Smart Tracer is all about customization. Using Crucial's custom programmed Ballistix Memory Overview Display (MOD) utility, you can manipulate the dual-color LEDs in real time and switch the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on the fly!
Features in the Crucial Ballistix MOD utility also allow you to view uptime, voltages, and set alarms for temperatures. That makes it one of the most customizable, responsive modules you'll find. In addition to the LED light controls, this tool lets you enjoy real-time temperature monitoring and keep tabs on your high-performance memory while you play.
Ballistix Smart Tracer - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL8 (8-8-8-24)
Heat sink, temperature monitoring, Blue/Orange activity LED's, unbuffered
Voltage
1.5 V
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL8 (8-8-8-24)
Non-ECC
Module Configuration
1024 x 64
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
