If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Put your game face on
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you. -
Timing is everything
- Ballistix Tactical - DDR3 - module - 8 GB - DIMM 240-pin - 2133 MHz / PC3-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC3-17000)
- Latency Timings
- CL11 (11-11-11-27)
- Heat sink, Intel Extreme Memory Profiles (XMP), Black PCB, unbuffered
- Voltage
- 1.65 V
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- Non-ECC
- Module Configuration
- 1024 x 64
- Voltage
- 1.65 V
- Colour Category
- Orange
