Your basket is empty
Ballistix Tactical 8GB (4GBx2) DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM 240pin
Quicklinx: C9TVWS00 Mfr#: BLT2C4G3D21BCT1J
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 2133MHz
Data Integrity: Non-ECC
£39.42 ex VAT
£47.30 inc VAT
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Ballistix Tactical - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC3-17000 )
Latency Timings
CL11 ( 11-11-11-27 )
Heat sink, Intel Extreme Memory Profiles (XMP), dual channel, Black PCB , unbuffered
Voltage
1.65 V
Limited lifetime warranty ( Germany - 10 years )
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.65 V
Colour Category
Orange
Ballistix Tactical 8GB (4GBx2) DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM 240pin Bundle deal on Ballistix Tactical 8GB (4GBx2) DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM 240pin
£60.61
saving £14.13
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-17000
Brand: Ballistix
Price Range Ex VAT: 0 - 50
