Your basket is empty
Ballistix Tactical 8GB (2x4GB) DDR3-1600 1.5V UDIMM Memory with Red and Green LEDs
Quicklinx: 7Y8XWS00 Mfr#: BLT2CP4G3D1608DT2TXRGCEU
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£34.24 ex VAT
£41.08 inc VAT
More to love.
We’re upping the ante on our Ballistix Tactical Series memory. Crucial BallistixTactical Tracer memory delivers advanced speeds and timings, activity-indicatingLEDs on the top edge and ground-effect LEDS along the bottom, and support fortemperature sensor and M.O.D. utilities along with an integrated heat spreader. It’sthe memory for serious gaming
Lights on.
The Ballistix Tactical Tracer is all about customisation. These modules are availablein either orange/blue and red/green colour combinations. By utilizing our customprogrammedBallistix Memory Overview Display (M.O.D.) utility, you can manipulatethe dual-colour LEDS in real time and switch between colour options. In addition,select from four different LED patterns, adjust brightness, or turn the LEDs on/off.
Utility work.
The Crucial Ballistix M.O.D. utility allows you to view uptime, voltages, and set alarmsfor temperatures, making it one of the most customisable, responsive modules you’llfind. In addition to the LED light controls, this tool also lets you enjoy real-timetemperature monitoring, so you can keep tabs on your high-performance memory.
Trusted name.
Ballistix Tactical Tracer modules are available in 2GB and 4GB module densitiesrunning at speeds up to DDR3-1866MHz. With lower latencies, they also supportthe latest Intel® and AMD® platforms. At Crucial, each one of our Ballistix modulespasses rigorous testing to meet or exceed specifications. Price competitive, highquality,and reliable, Crucial Ballistix Tactical Tracer modules are backed by a limitedlifetime warranty* and outstanding service and support.
Light up your gaming experience with the new Crucial Ballistix Tactical Tracer!
Features and benefits
  • Designed for performance enthusiasts, gamers and case modders
  • Enhanced heat spreader
  • On-the-fly customisable activity LEDs
  • Thermal sensor allows real-time temperature monitoring
  • Custom Ballistix M.O.D. utility to change LEDs, and monitor temperature
  • Advanced speeds and timings (XMP Profile)
  • Premium quality DRAM
  • Black PCB
  • Proven stability and reliability
  • Crucial: a trusted name in memory
  • Limited lifetime warranty
Ballistix Smart Tracer - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL8 ( 8-8-8-24 )
Heat sink, temperature monitoring, Red/Green activity LED's , unbuffered
Voltage
1.5 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL8 ( 8-8-8-24 )
Non-ECC
Module Configuration
512 x 64
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL8
Standard: PC3-12800
Brand: Ballistix
Price Range Ex VAT: 0 - 50
