Ballistix Tactical 4GB DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM 240pin
Quicklinx: C9TRWS00 Mfr#: BLT4G3D21BCT1J
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
  • Put your game face on
  • Timing is everything
Ballistix Tactical - DDR3 - module - 4 GB - DIMM 240-pin - 2133 MHz / PC3-17000 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-11-11-27)
Heat sink, Intel Extreme Memory Profiles (XMP), Black PCB, unbuffered
Voltage
1.65 V
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11 (11-11-11-27)
Non-ECC
Module Configuration
512 x 64
Voltage
1.65 V
Colour Category
Orange
