If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
- Ballistix Tactical - DDR4 - 32 GB: 4 x 8 GB - DIMM 288-pin
- Product Type
- RAM memory
- Capacity
- 32 GB: 4 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 3000 MHz (PC4-24000)
- Latency Timings
- CL16
- Dual channel, Black PCB, quad channel, Intel Extreme Memory Profiles (XMP 2.0), gunmetal grey heat spreader, unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty (Germany - 10 years)
- Capacity
- 32 GB: 4 x 8 GB
- Upgrade Type
- Generic
- DRAM
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL16
- Non-ECC
- Module Configuration
- 1024 x 64
- Voltage
- 1.35 V
- Colour Category
- Gray
