Ballistix Sport LT White 16GB DDR4-2666 1.2V DIMM Memory
Quicklinx: CQ3HWS00 Mfr#: BLS16G4D26BFSC
  • Speeds start at 2400 MT/s
  • Faster speeds and responsiveness than standard DDR4 memory
  • Ideal for gamers and performance enthusiasts
  • Multi-channel memory architecture maximizes data rates
  • Digital camo heat spreader available in white, gray and red
  • Easy plug-and-play installation
  • Intel XMP 2.0 profiles for easy configuration
  • Optimized for the latest Intel platforms
  • Limited lifetime warranty
Speed. Style. Sport. Get more out of your memory.
Designed for performance enthusiasts, gamers, and anyone who simply wants to get more out of their system, Ballistix Sport LT DDR4 memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Make your system go Ballistix.
Memory is fun when it's faster, when it's stylish, and when it helps your system perform at a higher level. Compared to standard DDR4 memory, that's exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times.
Install with ease.
Getting more out of your system should be easy — and that's exactly how we engineered Ballistix Sport memory. Using cutting-edge technology, intuitive module design, Intel XMP 2.0 profiles and more, we designed Ballistix Sport with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
Go covert.
With a stealth digital camo design and integrated heat spreader, Ballistix Sport LT is designed to be your memory lieutenant. Keep your system cool and collected while mowing down the opposition – whether that's a challenging spreadsheet or outmaneuvering an opponent.
Micron quality: Pro gamer reliability.
As the only major gaming brand that's built and tested from start to finish as part of a major memory manufacturer, Ballistix DRAM delivers a higher level of performance than regular PC gaming memory. For more than 35 years, we've engineered old-school DDR memory all the way to Ballistix DDR4 modules, which empower the future of gaming performance. Backed by competitive warranties, a hardcore community of fans, and a dedicated gamer support team, Ballistix memory is ready to take your in-game performance to the next level.
  • Make your system go faster
    Memory is fun when it's faster, when it's stylish, and when it helps your system perform at a higher level. Compared to standard PC memory, that's exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times.
  • Install with ease
    Getting more out of your system should be easy - and that's exactly how Ballistix Sport memory is engineered. Using the advanced technology, intuitive module design, and more, Ballistix Sport is designed with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
Ballistix Sport LT - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL16 (16-18-18)
Heat sink, dual rank, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-18-18)
Non-ECC
Voltage
1.2 V
Colour Category
White
