Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Make your system go faster
Memory is fun when it's faster, when it's stylish, and when it helps your system perform at a higher level. Compared to standard PC memory, that's exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times. -
Install with ease
Getting more out of your system should be easy - and that's exactly how Ballistix Sport memory is engineered. Using the advanced technology, intuitive module design, and more, Ballistix Sport is designed with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
- Ballistix Sport LT - DDR4 - kit - 16 GB: 4 x 4 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 4 x 4 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2666 MHz (PC4-21300)
- Latency Timings
- CL16 (16-18-18)
- Dual rank, quad channel, white heatsink, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty (Germany - 10 years)
- Capacity
- 16 GB: 4 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL16 (16-18-18)
- Non-ECC
- Module Configuration
- 512 x 64
- Voltage
- 1.2 V
- Colour Category
- White
