Product
Ballistix Sport LT Grey 32GB (4x8GB) DDR4-2400 1.2V DIMM Memory
Quicklinx: CRCFWS00 Mfr#: BLS4C8G4D240FSBK
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: Non-ECC
£208.49 ex VAT
£250.18 inc VAT
Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
  • Make your system go faster
    Memory is fun when it's faster, when it's stylish, and when it helps your system perform at a higher level. Compared to standard PC memory, that's exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times.
  • Install with ease
    Getting more out of your system should be easy - and that's exactly how Ballistix Sport memory is engineered. Using the advanced technology, intuitive module design, and more, Ballistix Sport is designed with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
Ballistix Sport LT - DDR4 - 32 GB: 4 x 8 GB - DIMM 288-pin - unbuffered
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL16 (16-16-16)
Heat sink, single rank, quad channel, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-16-16)
Non-ECC
Module Configuration
1024 x 64
Voltage
1.2 V
Colour Category
Gray
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL16
Standard: PC4-19200
Brand: Ballistix
Price Range Ex VAT: 150 - 300
