Product
Brand
Ballistix Sport LT DDR4 16GB (4x4GB) DIMM 288-pin 2400 MHz/PC4-19200 CL16 1.2V unbuffered
Quicklinx: BVSDWS00 Mfr#: BLS4C4G4D240FSB
Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Ballistix Sport LT - DDR4 - 16 GB: 4 x 4 GB - DIMM 288-pin
RAM memory
16 GB: 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL16 (16-16-16)
Heat sink, dual channel, Black PCB, quad channel, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-16-16)
Non-ECC
Module Configuration
512 x 64
Voltage
1.2 V
