Product
Brand
Ballistix Sport LT 16GB (8GBx2) DDR4 2400 MT/s PC4-19200 CL16 DR x8 Unbuffered SODIMM 260pin
Quicklinx: C7NJWS00 Mfr#: BLS2C8G4S240FSD
Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Ballistix Sport LT - DDR4 - 16 GB: 2 x 8 GB - SO-DIMM 260-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL16 (16-16-16)
Heat sink, dual channel, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL16 (16-16-16)
Non-ECC
Voltage
1.2 V
Colour Category
Gray
