The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
- Ballistix Sport - DDR4 - 32 GB: 4 x 8 GB - DIMM 288-pin
- Product Type
- RAM memory
- Capacity
- 32 GB: 4 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL16 (16-16-16)
- Ultra Low Voltage, unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 32 GB: 4 x 8 GB
- Upgrade Type
- Generic
- DRAM
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL16 (16-16-16)
- Non-ECC
- Module Configuration
- 1024 x 64
- Voltage
- 1.2 V
