Product
Ballistix Elite 8GB DDR4 3000 MT/s (PC4-24000) CL15 DR x8 Unbuffered DIMM 288pin
Quicklinx: C9KCWS00 Mfr#: BLE8G4D30AEEA
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 3000MHz
Data Integrity: Non-ECC
£54.79 ex VAT
£65.74 inc VAT
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
  • Elite force
  • Greatest
    Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
Ballistix Elite - DDR4 - 8 GB - DIMM 288-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL16 (16-17-17)
Temperature monitoring, black heatsink, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.35 V
Limited lifetime warranty (Germany - 10 years)
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-17-17)
Non-ECC
Module Configuration
1024 x 64
Voltage
1.35 V
Colour Category
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 3000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL16
Standard: PC4-24000
Brand: Ballistix
Price Range Ex VAT: 50 - 100
