The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Elite force
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design. -
Greatest
Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
- Ballistix Elite - DDR4 - kit - 8 GB: 2 x 4 GB - DIMM 288-pin - 3000 MHz / PC4-24000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 3000 MHz (PC4-24000)
- Latency Timings
- CL15 (15-16-16)
- Temperature monitoring, black heatsink, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty (Germany - 10 years)
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15 (15-16-16)
- Non-ECC
- Module Configuration
- 512 x 64
- Voltage
- 1.35 V
- Colour Category
- Black
