Your basket is empty
Ballistix Elite 16GB (8GBx2) DDR4 3000 MT/s (PC4-24000) CL15 DR x8 Unbuffered DIMM 288pin
Quicklinx: C9KPWS00 Mfr#: BLE2C8G4D30AEEA
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 3000MHz
Data Integrity: Non-ECC
£100.43 ex VAT
£120.51 inc VAT
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Ballistix Elite - DDR4 - 16 GB : 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz ( PC4-24000 )
Latency Timings
CL15 ( 15-16-16 )
Temperature monitoring, black heatsink, Black PCB, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.35 V
Limited lifetime warranty ( Germany - 10 years )
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 ( 15-16-16 )
Non-ECC
Module Configuration
1024 x 64
Voltage
1.35 V
Colour Category
Ballistix Elite 16GB (8GBx2) DDR4 3000 MT/s (PC4-24000) CL15 DR x8 Unbuffered DIMM 288pin Bundle deal on Ballistix Elite 16GB (8GBx2) DDR4 3000 MT/s (PC4-24000) CL15 DR x8 Unbuffered DIMM 288pin
£121.62
saving £14.13
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 3000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-24000
Brand: Ballistix
Price Range Ex VAT: 100 - 150
