Ballistix 8GB (2x4GB) DDR3 1866MHz CL10 1.5V 240pin Sport
Quicklinx: BX07WS00 Mfr#: BLS2C4G3D18ADS3J
Designed for gamers who are comfortable changing BIOS settings to unleash their memory's full potential, Sport XT modules offer blazing - fast DDR3 speeds up to 1866 MHz. With an expanded heat spreader that offers more surface area for heat dissipation, Sport XT modules enable better thermal performance. Coupled with an aggressive design and XMP profiles for easy configuration in Intel - supported systems, Sport XT modules deliver no-hassle performance so you can own your opponents.
Engineered to deliver fast and reliable performance memory for enthusiasts and mainstream users alike, the Crucial Ballistix Sport series is a great place to start. Touting all the usual benefits of a memory upgrade - faster load times, better system responsiveness, and increased ability to handle data-intensive games - Ballistix Sport modules also feature an array of additional features. With an eye-catching design, premium-quality DRAM, and a stylish integrated heat spreader for thermal performance, Ballistix Sport makes it easy to take your game to the next level. Since Ballistix Sport performance memory is budget-friendly and compatible with nearly every type of system, you'll be hard pressed to find a better win.
  • Ballistix Sport XT modules: aggressive performance
  • Get ready to play
Ballistix Sport XT - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin - unbuffered
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL10 (10-10-10-30)
Intel Extreme Memory Profiles (XMP), tall heatsink, dual channel, unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL10 (10-10-10-30)
Non-ECC
Voltage
1.5 V
