Ballistix 4GB Tactical DDR4 CL16 Unbuffered DIMM 1.2V 288pin
Quicklinx: BLC0WS00 Mfr#: BLT4G4D26AFTA
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: Non-ECC
£27.57 ex VAT
£33.08 inc VAT
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
  • Put your game face on
  • Timing is everything
Ballistix Tactical - DDR4 - 4 GB - DIMM 288-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL16 (16-17-17)
Dual rank, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), gunmetal grey heat spreader, unbuffered
Voltage
1.2 V
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-17-17)
Non-ECC
Module Configuration
512 x 64
Chips Organization
X4
Voltage
1.2 V
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2666MHz
Registered/Buffered: Unbuffered
CAS Latency: CL16
Standard: PC4-21300
Brand: Ballistix
Price Range Ex VAT: 0 - 50
