The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Elite force
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design. -
Greatest
Designed for unprecedented gaming performance, the Crucial Ballistix Elite series includes an enhanced mechanical heat spreader design, a sleek PCB, and integrated thermal sensors. That makes it the ideal choice for top-notch performance: enjoy the fastest speeds and best response times.
- Ballistix Elite - DDR3 - module - 4 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1866 MHz (PC3-14900)
- Latency Timings
- CL9 (9-9-9-24)
- Heat sink, unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-9-9-24)
- Non-ECC
- Module Configuration
- 512 x 64
- Voltage
- 1.5 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
