Ballistix 4GB DDR3 1600 MT/s (PC3-12800) CL8 @1.5V Tactical Tracer UDIMM 240pin
Quicklinx: 9K38WS00 Mfr#: BLT4G3D1608DT2TXOBCEU
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£32.04 ex VAT
£38.44 inc VAT
Crucial Ballistix Smart Tracer memory starts with everything you love about the Ballistix Tracer: activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom. And then Crucial has added more!
The Ballistix Smart Tracer is all about customization. Using Crucial's custom programmed Ballistix Memory Overview Display (MOD) utility, you can manipulate the dual-color LEDs in real time and switch the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on the fly!
Features in the Crucial Ballistix MOD utility also allow you to view uptime, voltages, and set alarms for temperatures. That makes it one of the most customizable, responsive modules you'll find. In addition to the LED light controls, this tool lets you enjoy real-time temperature monitoring and keep tabs on your high-performance memory while you play.
  • More to love
  • Lights on
  • Utility work
Ballistix Smart Tracer - DDR3 - 4 GB - DIMM 240-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL8 (8-8-8-24)
Heat sink, temperature monitoring, Blue/Orange activity LED's, unbuffered
Voltage
1.5 V
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL8 (8-8-8-24)
Non-ECC
Module Configuration
512 x 64
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL8
Standard: PC3-12800
Brand: Ballistix
Price Range Ex VAT: 0 - 50
