Your basket is empty
B-Tech Universal flat screen interface kit 30- 50"
Quicklinx: 8480WS00 Mfr#: BT8500/B
Marketing description is not available.
B-TECH BT8500 Universal Flat Screen Interface Kit - mounting component
Mounting component - wall-mountable
Mounting Components
Interface plate
Recommended Use
LCD / plasma panel
Recommended Display Size
30"-50"
Flat Panel Mount Interface
400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
Max Load Weight
70 kg
AV Furniture
Mounting component
Mounting Components
Interface plate
Recommended Use
LCD / plasma panel
Placing / Mounting
Wall-mountable
30"-50"
Max Load Weight
70 kg
