Product
B-Tech Projector Mount
Quicklinx: 8KGVWS00 Mfr#: BTEBT5835-075
35mm diameter pole designed for use with BT5820 Ceiling Mount - Attachment for mount at the bottom of the pole - Additional holes provided at 200mm increments allow poles to be cut to desired length (if required) - Features safety bolt holes at the top for secure installation - Can be used with BT7035 collars.
