Product
B-Tech Projector Ceiling Mount - 1m Drop
Quicklinx: CYWXWS00 Mfr#: BT5890-100/B
B-TECH System V BT5890-100 Mounting kit (ceiling plate, interface plate, pole) for projector.
B-TECH System V BT5890-100 - mounting kit
Mounting kit
Mounting Components
Ceiling plate, interface plate, pole
1 m
Recommended Use
Projector
Max Mounting Pattern Size
493 x 493 mm
Max Load Weight
10 kg
1 m
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
493 x 493 mm
Cable Management
Integrated cable management
Adjustments
Roll, tilt
Max Load Weight
10 kg
Swivel adjustment
