B-Tech Pole Mounted Universal Projector Mount with Tilt and Swivel
Quicklinx: 8RVKWS00 Mfr#: BT7819-888/B
Marketing description is not available.
B-TECH BT7819-888 - mounting component
Mounting component
Mounting Components
Carousel mounting bracket, universal mount, pole mount
Recommended Use
Projector
Max Load Weight
15 kg
B-TECH BT7850; System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
AV Furniture
Mounting component
Mounting Components
Recommended Use
Projector
Max Load Weight
15 kg
Ball joint
B-TECH BT7850 , B-TECH System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
