Your basket is empty
B-Tech LCD TFT Desk mount tilt swivel twin arm dual screen
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 7RGNWS00 Mfr#: BT7374/GB
Type: Desk Mount
Stock Status: Clearance
Stock Status: Used Stock
Sorry but this product has been discontinued.
View used stock
  • Designed for screens up to 24" (61cm) / 9kg (20lbs)
  • Fits screens with VESA mounting patterns: 75 x 75mm and 100 x 100mm
  • Supplied with both a desk clamp and grommet
  • Maximum extension: 457mm
  • Easy tilt adjustment: +/-40°
  • Features three swivel points on each arm: 360° at pole, 360° at pivot and 180° at interface
  • Easy height adjustment using tool-less locking ring
  • Simple installation with all fixings included
  • Available in stylish Graphite Black finish
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 7RGN 034028
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £16.81
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Desk Mount
Brand: B-Tech
Price Range Ex VAT: 0 - 50
