Your basket is empty
B-Tech Large Glass Shelf 500x380mm Glass Shelf 10mm Clear Glass
Quicklinx: BDN6WS00 Mfr#: BT7163/CG
Marketing description is not available.
B-TECH BT7163 - mounting component
Mounting component - pole mount
Mounting Components
Shelf
50 cm x 38 cm
Recommended Use
Audio/video components
Max Load Weight
7.5 kg
Material
Tempered glass
Clear glass
50 cm
38 cm
Material
Tempered glass
Clear glass
AV Furniture
Mounting component
Mounting Components
Shelf
Recommended Use
Placing / Mounting
Pole mount
Max Load Weight
7.5 kg
