Your basket is empty
B-Tech Generic Large Glass Shelf For use with Ø50mm and Ø60mm
Quicklinx: BPM6WS00 Mfr#: BT7174/CG
£38.14 ex VAT
£45.76 inc VAT
Marketing description is not available.
B-TECH PRO Install BT7174 - mounting component
Mounting component - pole mount, floor stand mountable
Mounting Components
Glass shelf, 2 mounting brackets
Recommended Use
DVD player / game console
Max Load Weight
15 kg
Material
Tempered glass
Clear glass
Material
Tempered glass
Clear glass
AV Furniture
Mounting component
Mounting Components
Recommended Use
Placing / Mounting
Pole mount, floor stand mountable
Max Load Weight
15 kg
Dimensions & Weight Details
Dimensions
Shelf - width: 50 cm, depth: 38 cm, height: 1 cm
Brand: B-Tech
Price Range Ex VAT: 0 - 50
