B-Tech BT7535 Wall Mount For LCD Display
Quicklinx: CRCCWS00 Mfr#: BT7535/S
BT7535 is a medium flat screen wall mount with double arm extension.
B-TECH BT7535 - mounting kit - for LCD display - silver
Mounting kit - wall-mountable
Mounting Components
Wall mount, dual arm
Adjustable Depth
14.5-56 cm
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
Up to 42"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
40 kg
Silver
Adjustable Depth
14.5-56 cm
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Up to 42"
Adjustments
Tilt
Max Load Weight
40 kg
