Product
B-TECH BT7523 Flat Screen Wall Mount with Tilt - wall mount
Quicklinx: 7WJDWS00 Mfr#: BT7523/PB
Type: Wall mount
17 in stock
£18.35 ex VAT
£22.02 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
Wall mount
Recommended Use
LCD / plasma panel
Recommended Display Size
15"-42"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
25 kg
Piano black
B-TECH BT7051, BT7052 50mm Accessory Collar, BT7260; System 2 BT7052
Piano black
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
15"-42"
Max Load Weight
25 kg
B-TECH BT7051, BT7052 50mm Accessory Collar, BT7260 , B-TECH System 2 BT7052
Type: Wall mount
Brand: B-Tech
Price Range Ex VAT: 0 - 50
