Your basket is empty
B-Tech 1.2m TV Stand with Shelf (for Vision Pod)
Quicklinx: 94QJWS00 Mfr#: BTF811/BW
Stock Status: Clearance
Hurry, only 1 left in stock!
£295.82 ex VAT
£354.98 inc VAT
Express delivery Order within the next 20 hours for delivery on Monday
1.2m TV Stand with 1 Shelf for screens up to 37" max weight 15kg - White
-Designed for LCD LED and Plasma flat panel TVs up to 37 (127cm) / 35kg (77lbs)
-Fits screens with VESA® and non-VESA® mounting patterns up to 600 x 400mm
-High gloss and premium finish
-360° revolving base
-Includes Accessory Shelf - Max weight: 10kg (22lbs)
-Concealed cable management
-Tempered glass shelf toughened to BS6206A standard
-Available in black and white
-Screen size: up to 37" (94cm)
-Max VESA® Fixing: up to 300 x 300mm
-Max weight: 15kg (33lbs)
-Max shelf weight: 10kg (22lbs)
-Glass shelf thickness: 8mm
W: 500mm (19.7")
D: 500mm (19.7")
H: Min:1150mm (45.2") Max: 1300mm (51.2") (to centre of mount)
-Tempered glass shelves toughened to BS6206A standard
Brand: B-Tech
Price Range Ex VAT: 150 - 300
