Product
Brand
Axis T90C20 Fixed Dome IR-LED Illuminator
Quicklinx: 9BV7WS00 Mfr#: 5024-201
As a high-intensity infrared illuminator for outdoor versions of AXIS P33 fixed dome network cameras, the outdoor-ready AXIS T90C Fixed Dome IR-LED enables the cameras to deliver high-quality images by increasing visibility in darkness.
With a sleek and compact design, AXIS T90C IR-LED provides fixed angle illumination for the outdoor, vandal-resistant cameras in the AXIS P33 series. The illuminator is controlled by a visible light sensor, which automatically turns the infrared light on when it detects darkness. The product has pre-mounted cables, which can be powered by low voltage DC input, and AXIS T90AC20 Fixed Dome IR-LED, which supports Power-over-Ethernet (PoE 802.3af) for easy installation.
The IR illuminators feature eight powerful high-intensity LEDs that provide a wide-angle light beam giving an AXIS P33 series camera a viewing range of 67-82 feet in complete darkness. Using the technology, the IR illuminators offer long-life performance, low power consumption of less than 15 W and require no additional maintenance.
AXIS P33 series and AXIS T90C IR-LED operate in tough outdoor conditions. The IR-LED is ideal for installations where a separate IR illuminator is not feasible or is aesthetically undesirable, such as at airports, railway stations, city buildings, and school and campus environments. The wall-mounted illuminators were designed to attach directly to the camera for easy installation.
AXIS T90C20 Fixed Dome IR-LED - infrared illuminator
Infrared illuminator
Indoor / Outdoor
Outdoor
Distance
30 m
Angle
180 degree(s)
Wave Length
850 nm
25.6 cm x 4.7 cm x 13 cm
0.7 kg
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, NEMA Type 4X, UL 60950-1, EN 60950-1
3 years warranty
AXIS P3343-VE Fixed Dome Network Camera, P3344-VE Fixed Dome Network Camera, P3346-VE Network Camera
Indoor / Outdoor
Outdoor
Distance
30 m
Angle
180 degree(s)
Wave Length
850 nm
25.6 cm
4.7 cm
13 cm
0.7 kg
White
Vandal-resistant
Limited warranty - 3 years
-40 °C
55 °C
