AXIS Q3708-PVE is a fixed dome network camera with three sensors. It gives you a 180º panoramic overview of large areas, using a single camera. And it's perfect for use in challenging light conditions, both during the day and at night.
Get the whole picture
Large outdoor spaces. Expansive halls. Oversized warehouses and parking lots. When you need a broad overview of a wide area, AXIS Q3708-PVE delivers. With three sensors, built into a single camera, it gives you a 180º panoramic overview of everything you want to observe. -
Excellent image quality - even in challenging light
AXIS Q3708-PVE captures smooth video in great detail, filming in high resolution at 30 frames per second. It offers Wide Dynamic Range (WDR) - forensic capture technology for clarity even when there are both dark and light areas in the scene. And it features Axis' Zipstream technology, which reduces storage and bandwidth needs, while capturing important details in full image quality.
- AXIS Q3708-PVE - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - tamper-proof / weatherproof
- 20.5 cm x 20.5 cm x 17.2 cm
- 2.5 kg
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1920
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 3 x 1/1.8" - 3 x 5 MP
- Minimum Illumination
- 0.3 lux - colour - F2.8 , 0.06 lux - B&W - F2.8
- Focal Length Control
- Fixed focal
- Focal Length
- 5 mm
- Lens Iris
- F/2.8
- Panning Range (degree)
- -180 to +180
- Tilting Range (degree)
- 18 to 75
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Voltage
- PoE Plus
- Sharpness control, white balance, auto exposure control, colour control, brightness control, Power over Ethernet, contrast control, Wide Dynamic Range (WDR), ONVIF support, Open Network Video Interface Forum (ONVIF), infrared cut filter, Privacy Mask Function, Video Motion Detection Technology, active tampering alarm, Text Caption Overlay, password protection, Variable Bitrate (VBR), Constant Bitrate (CBR)
- 3-year warranty
- Environmental Parameters (operating)
- -40 °C - 55 °C; 10 - 100% (non-condensing) relative humidity
- Form Factor
- Dome
- Wired
- 20.5 cm
- 20.5 cm
- 17.2 cm
- 2.5 kg
- Localisation
- Argentina, Australia, China, Japan, South Korea, Brazil, United Kingdom, United States, Europe
Camera
- Colour - Day&Night - fixed - outdoor - tamper-proof / weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 2560 x 1920
- Motion Detection
- Exposure Range
- 1 sec - 1/71500 sec
- Digital Video Capture Resolution
- 2560 x 1920, 480 x 270
- Frame Rate (max)
- RAM
- 2.5 GB
- Flash Memory
- 512 MB
Image Sensor
- 3 x 5 MP CMOS 3 x 1/1.8"
Lens Construction
- Fixed focal
- Focal Length
- 5 mm
- Lens Iris
- F/2.8
- Horizontal Field of View (degree)
- 180
Panning
- Range (degree)
- -180 to +180
Tilting
- Range (degree)
- 18 to 75
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
- Ports
- LAN/power - RJ-45
- EN 61000-3-2, EN 61000-3-3, EN55024, IEC 60529 IP66, EN 61000-6-1, ICES-003 Class A, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-30, KCC, FCC Part 15 B Class A, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-78, IEC 62262 IK10, EN 50121-4, IEC 62236-4, VCCI Class A, EN 50581, AS/NZS CISPR 22, RCM, IEC 60950-22, EN 60950-22, UL 60950-22, EN 55022 Class A, KN35, NEMA250 Type 4X, KN32 Class A
- White
- Power Requirements
- PoE Plus
- Power Device
- 25.5 Watt
- Limited warranty - 3 years
- -40 °C
- 55 °C
- Relative Humidity (operating)
- 10 - 100% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
