Axis Q1765-LE Outdoor Network Camera
Quicklinx: 9K13WS00 Mfr#: 0509-001
  • SDHC Memory Card
£1,294.03 ex VAT
£1,552.83 inc VAT
AXIS Q1765-LE network camera is a slim, bullet-style outdoor-ready network camera with 18x optical zoom and auto-focus. It delivers SMPTE-compliant HDTV 1080p video in multiple, individually configurable H.264 and motion JPEG video streams. The built-in IR illumination is provided by four, auto adjusting LEDs that are highly power-efficient. AXIS Q1765-LE can cover great distances providing both wide overviews as well as detailed images for identification purposes. In addition, Axis' unique Corridor Format allows effective monitoring with more resolution in vertical scenes such as long streets or long perimeters.
  • All features integrated in bullet-style
  • Convenient installation
    AXIS Q1765-LE is very convenient to install thanks to its light weight, one-cable installation, readily directed IR, support for standard Power over Ethernet and 24 V DC/AC input. The cameras mounting bracket is designed for installation on walls or ceiling of buildings for monitoring of entrances and perimeter. Together with compatible accessories, the AXIS-Q1765-LE can be mounted on poles for surveillance of parking lots or general city surveillance purposes.
AXIS Q1765-LE Network Camera - network surveillance camera
Network surveillance camera - fixed - outdoor
Audio
Yes: two-way audio capability
Camera Mount Type
Ceiling mount
14.6 cm x 21.9 cm x 10.5 cm
1.8 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
18 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.9"
Minimum Illumination
0.5 lux - colour - F1.6 - 30 IRE , 0.04 lux - B&W - F1.6 - 30 IRE , 0 lux - IR
Focal Length Control
Vari-focal
Focal Length
4.7 mm - 84.6 mm
Focus Adjustment
Automatic
Lens Iris
F/1.6-2.8
Ethernet 10Base-T/100Base-TX
Voltage
DC 8 - 28 V / AC 20 - 24 V / PoE
Backlight compensation, manual exposure, sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, ONVIF support, infrared cut filter, Arctic Temperature Control, 3D Privacy Mask Function, OptimizedIR
3-year warranty
Environmental Parameters (operating)
-40 °C - 50 °C; 10 - 100% relative humidity
Audio Support
Camera Mount Type
Ceiling mount
Wired
14.6 cm
21.9 cm
10.5 cm
1.8 kg
Camera
Colour - Day&Night - fixed - outdoor
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
1920 x 1080
Digital Zoom
12
Exposure Range
2 sec - 1/28000 sec
Digital Video Capture Resolution
1920 x 1080, 320 x 180
Frame Rate (max)
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/2.9"
Lens Construction
Vari-focal
Optical Zoom
18 x
Focal Length
4.7 mm - 84.6 mm
Lens Iris
F/1.6-2.8
Focus Adjustment
Automatic
Horizontal Field of View (degree)
4 - 59
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm , 1 x video - output
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, KCC Class A, IP66, EN 50121-4, VCCI Class A, KN24
Power Requirements
Software Included
Drivers & Utilities
Limited warranty - 3 years
-40 °C
50 °C
Relative Humidity (operating)
10 - 100%
9K13 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.96
Brand: Axis
Price Range Ex VAT: 1000 - 1500
