With the use of Power over LAN Midspan and Power over LAN Active Splitter, Axis network video products can receive both data and power over a single Ethernet cable. The Power over LAN (PoL) products enable Axis network cameras and video servers to be installed in areas where traditional power cabling and outlets are unavailable or difficult to install. Power over LAN offers an easier, faster and more cost-effective solution than installing new power outlets and electrical cabling.
Power over LAN Midspans are available in 1, 6 and 12-port versions. A Power over LAN Midspan uses the unused pairs in a standard Cat 5 network cable to supply power to PoL-enabled products.
- AXIS Power over LAN Midspan - PoE injector
- PoE injector - external
- Localisation
- United Kingdom
- Output Voltage
- -48 V
- Output connectors
- 8 x RJ-45
- Designed For
- AXIS 211, 221, 247, M1031, M1054, M1103, M1104, M1113, M1114, M7001, P1311, P1343, P1344, P1346, P1347, P1455, P5512, P7701, P8221, Q1755, Q1910, Q1921, Q7401, T90A01, T90C20; Network Camera 211
- Localisation
- United Kingdom
- Power Output Connectors Details
- 8 x RJ-45
- Output Voltage
- -48 V
- 8 x LAN - RJ-45
- Designed For
- AXIS 211, 211W Network Camera, 211W Surveillance Kit, 221 Network Camera, 221 Outdoor Verso Bundle, 247S Video Server, M1031-W Network Camera, M1031-W Surveillance Kit, M1054 Network Camera, M1054 Surveillance Kit, M1103 Network Camera, M1103 Surveillance Kit, M1104 Network Camera, M1104 Surveillance Kit, M1113 Network Camera, M1113-E Network Camera, M1114 Network Camera, M1114-E Network Camera, M7001 Covert Surveillance Kit, M7001 Video Encoder, P1311 Network Camera, P1343 Network Camera, P1343-E Network Camera, P1344 Network Camera, P1344-E Network Camera, P1346 Network Camera, P1346-E Network Camera, P1347 Network Camera, P1347-E Network Camera, P1455-LE, P1455-LE-3 License Plate Verifier Kit, P5512 PTZ Dome Network Camera, P5512-E PTZ Dome Network Camera, P7701 Video Decoder, P8221 Network I/O Audio Module, Q1755 Network Camera, Q1755-E Network Camera, Q1910 Thermal Network Camera, Q1910-E Thermal Network Camera, Q1921 Thermal Network Camera, Q1921-E Thermal Network Camera, Q7401 Video Encoder, T90A01 IR-LED 50 DEG POE, T90C20 Fixed Dome IR-LED , AXIS Network Camera 211
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
