The outdoor-ready AXIS P5534-E PTZ Dome Network Camera offers outstanding HDTV-quality video and 18x zoom, enabling surveillance of a large area and great details when zooming in. With quick and reliable installation features, it is ideal for city and perimeter surveillance, and for use at airports and train stations.
AXIS P5534-E provides HDTV 720p in compliance with SMPTE 296M standard of 1280 x 720 pixel resolution, full frame rate, HDTV color fidelity and a 16:9 format. The day and night camera can deliver multiple H.264 and Motion JPEG streams simultaneously. H.264 greatly optimizes bandwidth and storage use without compromising image quality, while Motion JPEG is supported for increased flexibility.
Compliance with SMPTE standards
AXIS P5534-E provides HDTV 720p in compliance with SMPTE 296M standard of 1280 x 720 pixel resolution, full frame rate, HDTV color fidelity and a 16:9 format. The day and night camera can deliver multiple H.264 and Motion JPEG streams simultaneously. H.264 greatly optimizes bandwidth and storage use without compromising image quality, while Motion JPEG is supported for increased flexibility. -
Exceptional zoom
The PTZ dome camera provides 18x optical and 12x digital zoom with autofocus. Due to its HDTV resolution, the camera's 18x zoom provides not only a level of detail that is comparable to a 36x-zoom, 4CIF camera, but also the extra advantage of a wider, 16:9 field of view. With the unique Auto-flip functionality, it can pan 360° to continuously follow an object. The camera's Advanced Gatekeeper functionality enables it to automatically move to a preset position when motion is detected in a pre-defined area. -
Wide operating temperatures
The IP66- and NEMA 4X-rated AXIS P5534-E provides cost-efficient installation since no external housing is required. It can operate in temperatures from -20°C (-4 °F) up to 50°C (122 °F). -
Power over Ethernet for easy installation
AXIS P5534-E is powered with High Power over Ethernet, which makes installation easy since only one cable is needed for carrying power, video and PTZ commands.
- AXIS P5534-E PTZ Dome Network Camera - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - dustproof / waterproof
- Audio
- Yes: two-way audio capability
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 18 x
- Max Resolution
- 1280 x 720
- Optical Sensor Type
- CCD - 1/3"
- Minimum Illumination
- 0.74 lux - colour - F1.6 , 0.04 lux - B&W - F1.6
- Focal Length
- 4.7 mm - 84.6 mm
- Focus Adjustment
- Automatic
- Ethernet 10Base-T/100Base-TX
- Backlight Compensation (BLC), sharpness control, digital image freeze, white balance, auto exposure control, colour control, alarm function, 720p HD movie recording, text recognition, SD-card slot, brightness control, Power over Ethernet, SDHC-card slot, Advanced Gatekeeper
- 3-year warranty
- Audio Support
- Wired
- Localisation
- United Kingdom, Europe
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor - dustproof / waterproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Digital Zoom
- 12
- Exposure Range
- 1/10000 sec - 1/4 sec
- Video Capture
- 1280 x 720 @ 25 fps , 320 x 180 @ 25 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CCD 1/3"
Lens Construction
- Optical Zoom
- 18 x
- Focal Length
- 4.7 mm - 84.6 mm
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 3.2 - 55.2
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone mono 3.5 mm , 1 x audio - line-out - mini-phone mono 3.5 mm
- Included Accessories
- Clear and smoked domes
- UL, C-Tick, VCCI Class B ITE, cUL, EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, CB, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, EN 60950-1, KCC, FCC CFR47 Part 15 B
- Power Device
- Power injector - external AC 120/230 V 17 Watt
- Limited warranty - 3 years
