Product
Brand
Axis P5534-E PTZ Dome Network Camera
Quicklinx: 7VCSWS00 Mfr#: 0315-002
The outdoor-ready AXIS P5534-E PTZ Dome Network Camera offers outstanding HDTV-quality video and 18x zoom, enabling surveillance of a large area and great details when zooming in. With quick and reliable installation features, it is ideal for city and perimeter surveillance, and for use at airports and train stations.
AXIS P5534-E provides HDTV 720p in compliance with SMPTE 296M standard of 1280 x 720 pixel resolution, full frame rate, HDTV color fidelity and a 16:9 format. The day and night camera can deliver multiple H.264 and Motion JPEG streams simultaneously. H.264 greatly optimizes bandwidth and storage use without compromising image quality, while Motion JPEG is supported for increased flexibility.
AXIS P5534-E PTZ Dome Network Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - dustproof / waterproof
Audio
Yes: two-way audio capability
Wired
Camera
Colour - Day&Night
Optical Zoom
18 x
Max Resolution
1280 x 720
Optical Sensor Type
CCD - 1/3"
Minimum Illumination
0.74 lux - colour - F1.6 , 0.04 lux - B&W - F1.6
Focal Length
4.7 mm - 84.6 mm
Focus Adjustment
Automatic
Ethernet 10Base-T/100Base-TX
Backlight compensation, sharpness control, digital image freeze, white balance, auto exposure control, colour control, alarm function, 720p HD movie recording, text recognition, SD-card slot, brightness control, Power over Ethernet, SDHC-card slot, Advanced Gatekeeper
3 years warranty
Audio Support
Wired
United Kingdom, Europe
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - dustproof / waterproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
12
Exposure Range
1/10000 sec - 1/4 sec
Video Capture
1280 x 720 @ 25 fps , 320 x 180 @ 25 fps
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CCD 1/3"
Lens Construction
Optical Zoom
18 x
Focal Length
4.7 mm - 84.6 mm
Focus Adjustment
Automatic
Horizontal Field of View (degree)
3.2 - 55.2
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone mono 3.5 mm , 1 x audio - line-out - mini-phone mono 3.5 mm
Clear and smoked domes
UL, C-Tick, VCCI Class B ITE, cUL, EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, CB, ICES-003 Class B, EN 61000-6-1, EN 61000-6-2, EN 60950-1, KCC, FCC CFR47 Part 15 B
Power injector - external AC 120/230 V 17 Watt
Limited warranty - 3 years
