The outdoor-ready AXIS P5512-E PTZ Network Dome Camera is a compact and affordably priced day and night pan/tilt/zoom camera. It is suitable for surveillance applications in areas such as parking lots, construction sites and business premises.
Compact PTZ dome for outdoor video surveillance
The outdoor-ready AXIS P5512-E PTZ Network Dome Camera is a compact and affordably priced day and night pan/tilt/zoom camera. It is suitable for surveillance applications in areas such as parking lots, construction sites and business premises. -
Pan/tilt/zoom capabilities
The camera enables users at a remote location to pan 360° for overview surveillance, tilt 180° and zoom in 12x with autofocus for detailed views. The Advanced Gatekeeper functionality enables the camera to automatically move to a preset position when motion is detected in a pre-defined area. -
High video quality
Thanks to the camera's day/night functionality, high image quality is maintained even in low light conditions. AXIS P5512-E provides H.264 and Motion JPEG streams at full frame rate in 4CIF resolution. H.264 greatly optimizes bandwidth and storage without compromising image quality. -
Easy and reliable installation
AXIS P5512-E supports standard Power over Ethernet for easy installation. The camera simply connects either to a PoE-enabled switch or via a PoE midspan to a switch with one network cable for carrying power, video and PTZ controls. The camera also has IP66 and NEMA 4X ratings, which ensure protection against dust, rain, snow, ice and corrosion.
- AXIS P5512-E PTZ Dome Network Camera - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - dustproof / weatherproof
- Camera Mount Type
- Wall mount
- 18.8 cm x 18.8 cm x 15.9 cm
- 1.2 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night - PAL
- Optical Zoom
- 12 x
- Max Resolution
- 704 x 576
- Optical Sensor Type
- CCD - 1/4"
- Minimum Illumination
- 1 lux - colour - F1.6 - 30 IRE , 0.01 lux - B&W - F1.6 - 30 IRE
- Focal Length Control
- Vari-focal
- Focal Length
- 3.8 mm - 46 mm
- Focus Adjustment
- Automatic
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 180
- Ethernet 10Base-T/100Base-TX
- Backlight Compensation (BLC), sharpness control, white balance, alarm function, brightness control, Power over Ethernet, SDHC-card slot, ONVIF support, Advanced Gatekeeper
- 3-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C; 20 - 80% relative humidity
- Camera Mount Type
- Wall mount
- Wired
- 18.8 cm
- 18.8 cm
- 15.9 cm
- 1.2 kg
- Localisation
- Australia, United Kingdom, Europe
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor - dustproof / weatherproof
- Video Format
- PAL
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 704 x 576
- Digital Zoom
- 4
- Exposure Range
- 1.6 sec - 1/50000 sec
- Video Capture
- 704 x 576 @ 25 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CCD 1/4"
Lens Construction
- Vari-focal
- Optical Zoom
- 12 x
- Focal Length
- 3.8 mm - 46 mm
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 4.4 - 51.6
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 100
Tilting
- Range (degree)
- 180
- Up to 100
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, IGMP, SSL, QOS
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Clear and smoked domes
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1, KCC Class B, IP66
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- -20 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
