Axis P5415-E PTZ Dome Network Camera
Quicklinx: 9MX6WS00 Mfr#: 0546-001
AXIS P5415-E PTZ Dome Network Camera is an attractively priced, outdoor-ready HDTV 1080p PTZ dome with 18x optical zoom for wall-mount surveillance installations. Designed to blend in with the environment, the camera is ideal for use in city and perimeter surveillance, parking houses and school yards. The camera's built-in wall bracket enables easy installation and lowers total installation costs since a separate mounting accessory is not required. The integrated sunshield can be easily removed and repainted to match the color of a building façade. The sloping form helps the camera resist attempts by vandals to pull it down with a rope.
AXIS P5415-E's innovations extend inside as well. It has a direct drive pan/tilt system that enables unsurpassed endurance. With no belts or gears, AXIS P5415-E is a reliable, low-maintenance PTZ camera.
  • Designed to blend in
  • Durable, low-maintenance mechanics
  • Detailed zoomed-in views
    The 18x optical zoom with autofocus, in combination with the HDTV 1080p resolution, provides detailed zoomed-in views. The camera's very light sensitive image sensor enables it to provide high quality video in low light situations. At night, its day/night functionality allows it to make use of infrared light from available light sources to produce high quality black and white video. When mounted on the corner of a building, AXIS P5415-E enables a 270° pan for wide area coverage. Support for advanced gatekeeper enables the camera to automatically pan, tilt and zoom in to a preset position when motion is detected in a predefined area.
  • Two-way audio and I/Os
    The camera has a hidden junction box that supports two-way audio, a memory card slot, four configurable inputs/outputs to external devices, and the option of using either 24 V DC or Power over Ethernet Plus (IEEE 802.3at).
AXIS P5415-E PTZ Dome Network Camera 50 Hz - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - vandal / waterproof
Audio
Yes: two-way audio capability
Camera Mount Type
Wall mount
3.5 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
18 x
Max Resolution
1920 x 1080
Optical Sensor Type
CMOS - 1/2.9"
Minimum Illumination
0.5 lux - colour - F1.6 - 30 IRE , 0.04 lux - B&W - F1.6 - 30 IRE
Focal Length
4.7 mm - 84.6 mm
Focus Adjustment
Automatic
Lens Iris
F/1.6-2.8
Panning Range (degree)
-135 to +135
Tilting Range (degree)
0 to 90
Ethernet 10Base-T/100Base-TX
Voltage
DC 24 V / PoE Plus
Backlight compensation, manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, contrast control, ONVIF support, Advanced Gatekeeper, infrared cut filter, 3D Privacy Mask Function, text stamp, SDXC-card slot
3-year warranty
Environmental Parameters (operating)
-20 °C - 50 °C; 10 - 100% relative humidity
Audio Support
Camera Mount Type
Wall mount
Wired
3.5 kg
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - vandal / waterproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Digital Zoom
12
Exposure Range
2 sec - 1/28000 sec
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/2.9"
Lens Construction
Optical Zoom
18 x
Focal Length
4.7 mm - 84.6 mm
Lens Iris
F/1.6-2.8
Focus Adjustment
Automatic
Horizontal Field of View (degree)
4 - 59
Panning
Range (degree)
-135 to +135
Speed (degree/sec)
Up to 400
Titling
Range (degree)
0 to 90
Speed (degree/sec)
Up to 400
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone 3.5 mm
Clear dome cover, sunshield
C-Tick, CISPR 22 Class B, EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-27, IEC 60068-2-6, FCC CFR47 Part 15 B, KCC Class B, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, ISO 4892-2, EN 50121-4, IEC 62236-4, VCCI Class B, EN 50581, KN24
Power Requirements
DC 24 V / PoE Plus
Software Included
Drivers & Utilities
Limited warranty - 3 years
-20 °C
50 °C
Relative Humidity (operating)
10 - 100%
9MX6 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
9MX6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
9MX6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.47
9MX6 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.05
