AXIS P3384-VE camera provides outstanding video quality including wide dynamic range (WDR) with 'dynamic capture' ensuring that no part of the image is too dark or too bright. The camera is suitable for installations close to large windows and entrances in buildings, in tunnel passages and other areas with bright sunlight and dark shadows, or other strong variations in light.
AXIS P3384-VE integrates Axis Lightfinder technology. The superb light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components.
Outstanding wide dynamic range capabilities with dynamic capture
AXIS P3384-VE camera provides outstanding video quality including wide dynamic range (WDR) with 'dynamic capture' ensuring that no part of the image is too dark or too bright. The camera is suitable for installations close to large windows and entrances in buildings, in tunnel passages and other areas with bright sunlight and dark shadows, or other strong variations in light. -
Lightfinder technology and P-iris control
AXIS P3384-VE integrates Axis Lightfinder technology. The superb light sensitivity, with maintained colors even in very poor lighting conditions, is obtained by a combination of Axis' expertise in image processing, system-on-chip development and selection of the best optical components. The camera also supports P-iris control, allowing the camera to precisely control the position of the iris. The iris opening is optimized for depth of field, lens resolution and light inlet, resulting in superb image quality with optimal sharpness. -
Vandal-resistant and weather-proof installations
AXIS P3384-VE with its weather-proof and vandal-resistant casing is a fixed dome perfectly adapted for harsh environments. It operates in extreme temperatures from -40-degree to 55-degree, powered by standard Power over Ethernet (IEEE 802.3af) only. It is the perfect solution for video surveillance systems in areas with tough quality and efficiency requirements such as airports, city surveillance, and banking, school and university campuses.
- AXIS P3384-VE Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - outdoor - vandal / weatherproof
- Audio
- Yes: two-way audio capability
- 17.8 cm x 17.8 cm x 12.3 cm
- 1.7 kg
- White
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3 x
- Max Resolution
- 1280 x 960
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0.5 lux - colour - F1.2 , 0.08 lux - B&W - F1.2
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 9 mm
- Lens Iris
- F/1.2
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 160
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, infrared cut filter, P-Iris control, Lightfinder technology, password protection
- 3-year warranty
- Environmental Parameters (operating)
- -40 °C - 55 °C; 10 - 100% relative humidity
- Audio Support
- Form Factor
- Dome
- Wired
- 17.8 cm
- 17.8 cm
- 12.3 cm
- 1.7 kg
Camera
- Colour - Day&Night - fixed - outdoor - vandal / weatherproof
- Digital Video Format
- MJPEG, H.264, AVC
- Max Digital Video Resolution
- 1280 x 960
- Exposure Range
- 2 sec - 1/24500 sec
- Video Capture
- 1280 x 960 @ 30 fps , 160 x 120 @ 30 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/3"
Lens Construction
- Vari-focal
- Optical Zoom
- 3 x
- Focal Length
- 3 mm - 9 mm
- Lens Iris
- F/1.2
- Horizontal Field of View (degree)
- 30 - 84
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 160
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Included Accessories
- Smoked dome cover
- VCCI, C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-30, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, IEC 62262 IK10
- White
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- -40 °C
- 55 °C
- Relative Humidity (operating)
- 10 - 100%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
