Axis P3367-V vandal resistant Network Camera
Quicklinx: BNP0WS00 Mfr#: 0406-001
  • SDHC Memory Card
The indoor AXIS P3367-V network camera, vandal-resistant, is suitable for any application that requires video surveillance coverage of a large area or extremely high image detail in a limited area. Examples include airport halls, train stations, parking lots, city surveillance, school halls and campuses.
The day and night fixed dome delivers 5-megapixel resolution video at 12 frames per second and support HDTV 1080p video at 30 frames per second. To help minimize bandwidth and storage needs, AXIS P3367-V camera features H.264 video compression, powerful digital pan/tilt/zoom capabilities and multi-view streaming, which enables cropped areas of interest to be streamed simultaneously instead of the full view. AXIS P3367-V can be installed easily and quickly through the combination of smart features such as remote zoom for adjusting the angle of view over the network and remote focus that eliminates the need for manual focusing.
AXIS P3367-V Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - vandal-proof
Audio
Yes: two-way audio capability
14.8 cm x 14.8 cm x 10.4 cm
730 g
Wired
Camera
Colour - Day&Night
Optical Zoom
3 x
Max Resolution
2592 x 1944
Frame Rate (max)
Optical Sensor Type
CMOS - 1/3.2" - 5 MP
Minimum Illumination
0.2 lux - colour - F1.2 , 0.04 lux - B&W - F1.2
Focal Length Control
Vari-focal
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2 - auto iris
Panning Range (degree)
360
Tilting Range (degree)
160
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Exposure compensation, manual white balance, motion sensor, Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), SDHC-card slot, AXIS Video Hosting System (AVHS), Open Network Video Interface Forum (ONVIF), infrared cut filter, P-Iris control, Audio Detect, digital PTZ function
3-year warranty
Environmental Parameters (operating)
0 °C - 50 °C; 15 - 85% (non-condensing) relative humidity
Audio Support
Dome
Wired
14.8 cm
14.8 cm
10.4 cm
730 g
Camera
Colour - Day&Night - fixed - vandal-proof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
2592 x 1944
Exposure Range
1/28000 sec - 2 sec
Video Capture
2048 x 1536 @ 20 fps , 1920 x 1080 @ 30 fps , 1600 x 1200 @ 30 fps , 2592 x 1944 @ 12 fps
RAM
512 MB
Flash Memory
128 MB
Image Sensor
5 MP CMOS 1/3.2"
Lens Construction
Vari-focal
Optical Zoom
3 x
Focal Length
3 mm - 9 mm
Lens Iris
F/1.2 auto iris
Horizontal Field of View (degree)
30 - 84
Panning
Range (degree)
360
Tilting
Range (degree)
160
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSL, QOS, CIFS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Clear dome cover, smoked dome cover, mounting kit
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, EN 60950-1, IK10
Power Requirements
PoE
Software Included
Drivers & Utilities
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
BNP0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
