Your basket is empty
Axis P3364-LV Dome Network Camera
Quicklinx: 9C61WS00 Mfr#: 0486-001
The AXIS P3364-LV is a 1-megapixel day and night fixed dome network camera that offers superb video performance. AXIS P3364-LV features built-in IR illumination based on long-life LED technology that is highly power efficient. This results in high-quality, low-noise video also when the environment is completely dark. The built-in IR solution in AXIS P3364-LV automatically adapts the illumination angle with the zoom level, which simplifies installation.
AXIS P3364-LV 12mm - network surveillance camera
Network surveillance camera - fixed dome - vandal-proof
Audio
Yes: two-way audio capability, built-in microphone
14.8 cm x 14.8 cm x 9.6 cm
670 g
White
Wired
Camera
Colour - Day&Night
Optical Zoom
3.6 x
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.18 lux - colour - F1.4 , 0.04 lux - B&W - F1.4 , 0 lux - IR
Focal Length Control
Vari-focal
Focal Length
3.3 mm - 12 mm
Lens Iris
F/1.4
Panning Range (degree)
360
Tilting Range (degree)
170
Ethernet 10Base-T/100Base-TX
Voltage
PoE Plus
Backlight compensation, manual exposure, sharpness control, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, image mirror, Wide Dynamic Range (WDR), ONVIF support, infrared cut filter, built-in IR illuminator, Privacy Mask Function, P-Iris control, text stamp, Video Motion Detection Technology, tamper-detection, Lightfinder technology
3 years warranty
Environmental Parameters (operating)
0 °C - 50 °C; 10 - 85% (non-condensing) relative humidity
Audio Support
Wired
14.8 cm
14.8 cm
9.6 cm
670 g
Camera
Colour - Day&Night - fixed dome - vandal-proof
Digital Video Format
MJPEG, H.264, AVC
Max Digital Video Resolution
1280 x 960
Motion Detection
Exposure Range
2 sec - 1/24500 sec
RAM
256 MB
Flash Memory
128 MB
Image Sensor
CMOS 1/3"
Lens Construction
Vari-focal
Optical Zoom
3.6 x
Focal Length
3.3 mm - 12 mm
Lens Iris
F/1.4
Horizontal Field of View (degree)
24 - 82
Panning
Range (degree)
360
Titling
Range (degree)
170
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP, QOS
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
Supported Memory Cards
SDXC Memory Card
C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-64, IEC 60068-2-1, IEC 60068-2-2, IEC 60068-2-14, IEC 60068-2-78, IEC 62262 IK10, EN 62471:2008
White
Power Requirements
PoE Plus
12.1 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
50 °C
Relative Humidity (operating)
9C61 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
9C61 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
9C61 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
9C61 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
