The AXIS P3346 is a 3-megapixel day and night fixed dome network camera that offers superb video performance. It delivers full frame rate HDTV 1080p (1920 x 1080) in compliance with the SMPTE 274M standard in resolution, color representation, 16:9 aspect ratio and frame rate. Multiple H.264 streams, as well as Motion JPEG streams, can be provided simultaneously. The camera also supports digital pan/tilt/zoom and multi-view streaming, where the full view and several areas cropped from the full view can be streamed simultaneously. The remote zoom adjusts the angle of view over the network and the remote focus eliminates the need for manual focusing.
High-performance video
The AXIS P3346 is a 3-megapixel day and night fixed dome network camera that offers superb video performance. It delivers full frame rate HDTV 1080p (1920 x 1080) in compliance with the SMPTE 274M standard in resolution, color representation, 16:9 aspect ratio and frame rate. Multiple H.264 streams, as well as Motion JPEG streams, can be provided simultaneously. The camera also supports digital pan/tilt/zoom and multi-view streaming, where the full view and several areas cropped from the full view can be streamed simultaneously. The remote zoom adjusts the angle of view over the network and the remote focus eliminates the need for manual focusing. -
Advanced iris control
AXIS P3346 also features P-Iris, a new and revolutionary precise iris control system that provides optimal image quality in all lighting conditions. It provides images with better contrast, clarity, resolution and depth of field. Having good depth of field - where objects at different distances from the camera are in focus simultaneously - is important in the video monitoring of, for example, a long corridor or parking lot. It also features wide dynamic range and day/night functionality enable clear images both in daylight and in dark lighting conditions. -
Tamper-resistant casing
AXIS P3346 with its tamper-resistant casing, is a fixed dome specifically designed for indoor environments where discreet and compact solutions are required. It is the perfect solution for video surveillance in areas such as retail stores, governmental buildings and airports.
- AXIS P3346 Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - tamper-proof
- Audio
- Yes: two-way audio capability, built-in microphone
- 14.8 cm x 14.8 cm x 10.1 cm
- 490 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3 x
- Max Resolution
- 2048 x 1536
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0.5 lux - colour - F1.2 , 0.08 lux - B&W - F1.2
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 9 mm
- Lens Iris
- F/1.2 - auto iris (video)
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 360
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Motion sensor, Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), SDHC-card slot, infrared cut filter, P-Iris control
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 50 °C; 15 - 85% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Wired
- 14.8 cm
- 14.8 cm
- 10.1 cm
- 490 g
Camera
- Colour - Day&Night - fixed - tamper-proof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 2048 x 1536
- Exposure Range
- 1/35500 sec - 1/6 sec
- Video Capture
- 2048 x 1536 @ 20 fps , 1920 x 1080 @ 30 fps , 1600 x 1200 @ 30 fps
- RAM
- 256 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/3"
Lens Construction
- Vari-focal
- Optical Zoom
- 3 x
- Focal Length
- 3 mm - 9 mm
- Lens Iris
- F/1.2 auto iris (video)
- Horizontal Field of View (degree)
- 30 - 84
- Vertical Field of View (degree)
- 22 - 63
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 360
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, IGMP
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-in/microphone - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone 3.5 mm
- Included Accessories
- Mounting bracket, smoked dome cover
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, EN 60950-1
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 15 - 85% (non-condensing)
