AXIS P1435-LE network camera ensures compact and cost-effective HDTV surveillance for any light condition. With features such as Lightfinder and WDR, the bullet-style AXIS P1435-LE provides excellent image quality in HDTV 1080p resolution, even in complex light conditions. In addition, the camera supports pixel counter, remote zoom and focus, as well as P-Iris control. The day and night camera is ideal for 24/7 video surveillance, in exposed outdoor areas such as parking lots and service stations, and for general indoor surveillance purposes wherever a compact camera is needed.
Excellent image quality
AXIS P1435-LE with its varifocal, P-Iris lens provides excellent image quality at up to 60 frames per second. The P-Iris control provides optimal depth of field, resolution, image contrast and clarity. -
Lightfinder and Wide Dynamic Range (WDR)
With Wide Dynamic Range - Forensic Capture, the camera provides perfectly balanced video quality in scenes with strong variations in light, while Axis' Lightfinder technology enables outstanding image usability in poor light. The camera can seamlessly transition between handling WDR and low-light conditions. -
Built-in IR-LEDs and OptimizedIR
AXIS P1435-LE offers OptimizedIR, Axis' power-efficient LED technology that provides an adaptable angle of IR illumination. With OptimizedIR, the camera provides automatic illumination of a scene in complete darkness, in case of an event or when requested by a user. The improved IR LED illumination is perfect for discovering objects in a range of up to 30 meters. -
Edge storage and Zipstream
AXIS P1435-LE offers support for edge storage that makes it possible to record video directly to a storage such as a microSD / SDHC card, thereby creating a flexible and reliable video surveillance system. In addition, Axis' Zipstream technology lowers bandwidth and storage requirements without costly and complicated integration. Zipstream ensures that important details in the image get enough attention in the video stream while unnecessary data can be removed. -
Ease of installation
AXIS P1435-LE has a compact, low weight casing and integrated bracket for wall or ceiling mount. AXIS P1435-LE offers easy installation with remote zoom and focus for fine tuning of the picture from a computer. Power over Ethernet supplies power to the cameras through the network, eliminating the need for power cables and reduces installation costs. -
I/O ports
The input / output ports can be used for simple notification to an alarm panel or control of a relay. The input is also ideal when using a PIR motion detector.
- AXIS P1435-LE - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- 13.2 cm x 26 cm x 13.2 cm
- 800 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3.5 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 60 frames per second
- Motion Detection
- Video Modes
- 1080/60p
- Optical Sensor Type
- CMOS - 1/2.8"
- Minimum Illumination
- 0.12 lux - colour - F1.4 , 0.02 lux - B&W - F1.4 , 0 lux - infrared LEDs on
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 10.5 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.4 - auto iris (P-Iris)
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Manual white balance, Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, Power over Ethernet, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, infrared cut filter, Privacy Mask Function, Video Motion Detection Technology, digital PTZ function, Text Caption Overlay, password protection, OptimizedIR, Zipstream technology
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 60 °C; 10 - 100% relative humidity
- Wired
- 13.2 cm
- 26 cm
- 13.2 cm
- 800 g
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080/60p
- Exposure Range
- 2 sec - 1/66500 sec
- Infrared LEDs
- Infrared Distance
- 30 m
- Video Capture
- 1920 x 1080 @ 60 fps , 1920 x 1080 @ 50 fps , 1920 x 1080 @ 30 fps , 1920 x 1080 @ 25 fps
- RAM
- 512 MB
- Flash Memory
- 256 MB
Image Sensor
- CMOS 1/2.8"
Lens Construction
- Vari-focal
- Optical Zoom
- 3.5 x
- Focal Length
- 3 mm - 10.5 mm
- Lens Iris
- F/1.4 auto iris (P-Iris)
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 35 - 95
- Vertical Field of View (degree)
- 20 - 51
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, TLS, IPv4, IPv6, Bonjour, RTCP, SMB, IGMP, SSH, SSL, QOS, CIFS, SFTP
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Ports
- LAN/power - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Mounting bracket
- EN55024, IEC 60529 IP66, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, NEMA Type 4X, EN 61000-6-2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60068-2-27, IEC 60068-2-6, IP66, IEC 60068-2-1, IEC 60068-2-2, EN 50121-4, IEC 62236-4, VCCI Class B, KN24, RCM, IEC 60950-22, EN 60950-22, UL 60950-22, KCC KN22 Class B, AS/NZS CISPR 22 Class B
- Power Requirements
- PoE
- Power Device
- 11 Watt
- Limited warranty - 3 years
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 10 - 100%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
